[WANTED] 340 360 Engine Brackets
Maybe I should call them motor mounts? But again. Not the rubber parts. Those I have.
If you need the metal brackets that bolt to block and has one hole for the rubber insulator stud and rubber piece has stud that bolts to frame plate, I have them. Shipped to lower 48 for $40 total.
You turned down my set ( I guess 'too' expensive ) , and you didn't the $40 set offered above! What is it you want?
The other gentleman has never sent photos yet. So No! I have not turned them down.
