11zman67
All new complete balanced 372 stroker Scat ***.Pistons are flat top Icon,Block year is 1970,roller timing set from MRE, Milling m-72HV oil pump,main bearing stud girdle from Hughes,timing chain tensioner from Hughes,oil baffle under alum. intake [7576] air gap,alum. water pump,alum. valve covers,Mildon 8 qt. oil pan,Pro Street dampner,Comp Cams hydr.and lifters,RHS-INDY X heads with large valves,S.S. roller 1.6 rockers, Manley push rods,and everything else new to complete.Asking $6200. please PM for any questions.Thanks,Lz.
