moparraceman
340 std bore, crank std-std, 8-68 really 69 block been cleaned, new freeze plugs, and cam bearings, fresh hone .new std speed pro pistons ,new rings, clevite rod and main bearings.rods with new arp bolts ,nice stock pan ,pick up and hv pump,and windage tray.front timing cover ,like new used hp comp timing chain set ,stock crank balancer,also oil pump dist drive gear and shaft no cam no heads misc water and fuel pump,water pump pulley $1800 pick up ohio
