[SOLD] 340 block and crank misc parts
moparraceman
mansfield ohio
340 std bore, crank std-std, 8-68 really 69 block been cleaned, new freeze plugs, and cam bearings, fresh hone .new std speed pro pistons ,new rings, clevite rod and main bearings.rods with new arp bolts ,nice stock pan ,pick up and hv pump,and windage tray.front timing cover ,like new used hp comp timing chain set ,stock crank balancer,also oil pump dist drive gear and shaft no cam no heads misc water and fuel pump,water pump pulley $1800 pick up ohio
Can you post the VIN on the block? It is on the passenger side by the oil pan rail on a flat surface machined on the block. My 69 GTS still needs it's original block, and the date code is right in the area where mine would have been assembled!
my swinger is looking for its original motor as well, please post vin.
did you change your mind on the motor didnt hear back from you thanks
No sir im still intrested, is it ok to call you in a little bit? I apologize, I just got busy with work and forgot, been a crazy week with the holiday and all. Trying to play catch up.
