dpmalibu
I just picked up a 73' Dart Sport 340 . Its a basket case so its going to be parted out. Here are whats left of the drivetrain :
This is not the original block to this car. Block needs to be honed due to surface rust in cylinders. It does have new freeze out plugs and cam bearings. bearing have some surface rust from sitting. casting #'s are 2780930-340-5 and date code is 1/12/73 Asking $525 B/O
Stock cast crankshaft from the 340. In very good shape. its wrapped in plastic so there is no rust on journals. $150
"J" casting cylinder heads need to be redone. Heads are clean casting #'s are 3418915-F and 3418915-C $250 B/O
Driver side exhaust manifold from 340 ( original from this car) $70
8.25 rear sure grip w/ 3.23 gears has 86k miles on it. Comes complete drum to drum and e-brake cables. $550
727 trans came out of smae car. has 86k miles on it. Needs to be rebuilt $175
V8 k-member out of same car $150
power steering box $50
drag link $25
original 340 air cleaner base (don't have top) $40
located in Hatboro,Pa
drag link $25
