340 Block Max Hp
345man
mopar member
how much hp do you guys think a factory 340 block will hold with no pouring but it has main studs?
I would say around 500hp is what they probably take before having cap walk issues.
My 340 based 416 stroker is pushing 520+ h.p. no issues i'm aware of yet with the block..the Eagle rods i used are a different story.:angry7::angry7:
Been running 580hp, and 600lbs of torque out of a 340 block, 419c.i motor.... low rpm though, at 5900.... and just raced 3000+ miles and countless amounts of drag racing without a single problem....
but then again, that's just my experience
is that the dart from bullrun, great looking car anyway:toothy10:
i no you can't say how you did but did you make us proud at fabo, and is the dart sub lime or sassy grass?:blob:
It's sub lime green, and can't say a word :bootysha: :-D
thats cool,:toothy10::-D can't wait to watch the new season, whats the motor combo, that some big hp numbers
Pump gas 419ci, dual plane intake, 850 holley, eldy heads, hydraulic roller cam, etc
580hp and 600+tq all day with lower rpms 6200 or so with main studs line honed with girdle 4340 crank and H beam rods...............
planning on doing a 418 in the next few months. Also what rockers are you using. I'm running th mp 292 509 right now. Its going to be a street strip car. Running 12.60's with now. thanks
Hughes Solid Cam, Cool Face Lifters, Edelbrock Stage 3 magnum heads from Hughes, Hughes 1.6 Rockers and Jomar Rocker Girdles.
Cam Specs.......
HUG HTL5660AS
CAMSHAFT, SOLID 106º LSA+3
FLAT TAPPET SOLID
$190.00
Flat Tappet Solid
. Hot street/bracket racing. Single plane intake manifold. 1 7/8" Big Block and 1 ¾" Small Block primary tube headers. 4.10:1 rear gear ratio. 4000rpm stall speed. HP ported Stage II cylinder heads. 190psi suggested cylinder pressure.
VIEW OUR CAMSHAFT F.A.Q. PAGE.
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .579"
.587"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .614"
.626"
Intake Duration at .050"
Exhaust Duration at .050" 256°
260°
Lobe Separation Angle 106
Intake Opening at .050"
Exhaust Opening at .050" 25° BTC
59° BBC
Intake Closing at .050"
Exhaust Closing at .050" 51° ABC
21° ATC
Min. Suggested Cylinder PSI 190
Sweet Spot RPM 2800 - 6600
Thanks for the info. Right now just filling my head with different combo's right now. You always want something dependable that you don't have to wrench on ever other day like you would a chevy. LOL
i'm thinking of going with a hughes cam in mine also, i have there whole top end already
