[WANTED] 340 dual point distributor
toypar
Hermiston, Or
Rating - 0%
0   0   0
looking for a 340 4 speed dual point distributor. It’s for a 1969 dart. Number should be 2875782-IBS-4015B, but it doesn’t have to be year correct.
I'm sure I have one. Will look tomorrow.
I have one as well if others fall thru.
Not sure of the year. 69 or 68 . ? It turns smoothly. It is a good distributor . $200 + shipping
I could only find one right now and it does not have a tag on it. I'm sorry thought I could get you one on the cheap.
I have a low mileage excellent Factory Dual Point that is off
my 1968 GTS 4 Speed Dart or my 1970 Duster 340 4 Speed.
It does not have the tag on it so I am not sure which one but
I think the 1968 Dart GTS.
It has been on the shelf for near 50 years. I put aftermarket
Ignitions in both these cars when they were less than a year old
and made them into dedicated race cars.
The shaft is extremely tight and this distributor ran up to 7500 without
point float (aftermarket HP Points) or timing moving = Absolutely the best
Dual Point I have every owned. If there is any wear or slop = they just do
not work well over 5000!
Even the Cap look near new!
If you are building a show restoration - It will need a bit of cosmetic work
to look perfect as it has rolled around and sat on the shelf and been moved'around
for the last 50 years. It is mechanically excellent.
$200.00
I will put in a For Sale Ad tonight and post pics!
