340 Duster Fender Tag break Down
scrag
Mount Airy MD
I decoded a Fender Tag and was wondering about some of the "options".
Also does anyone know about the Export dusters (read the fender tag break down).
VS29:
Plymouth Valiant,Duster
Special
2 Door Sports Hardtop
H08: 340 275HP 1-4BBL 8 CYL
1970
Export
XXXXXX: Sequence number
E55: 340 cid 4 barrel V8 275hp
D32: Heavy Duty Automatic Transmission
FJ5: Sublime Exterior Color
L4X9: Trim - Low, Vinyl Split Bench Seat, Black
TX9: Black Int. Door Frames
CO1: Build Date: December O1
022085: Order number
FJ5: Sublime Top Color
A62: Rallye Instrument Cluster Package
M21: Roof drip rail moldings
N41: Dual Exhaust
N85: Tachometer
R11: Radio Solid State AM (2 Watts)
V6X: Longitudinal Stripes, Black
V8X: Tranverse Stripes, Black
Y05: Build to USA Specs
EN2: End of Sales Codes
Car has a bench seat with arm rest. Not a normal split bench.
Hi scrag, your be sure that the eighth digit of VIN is 8? your review, however, the eighth digit decodes the assembly plant, it really can be B, which means it was manufactured in DodgeMain, Hamtramck, MI. as you determine that this be export?
It is a B vice an 8 so it was built in Hamtramck. I am just trying to decide if it is worth the time to invest in it. What is the price range of a car in fair - poor condition (body has rot between the rear window and trunklid, front fenders, hood and trunk lid have been replaced - needs dash pad is shot and the cluster is mariginal - seats look good, headliner is MIA, surface rust in the trunk and inner fenders - minor dents in the lower rear qutrs and the right side looks like it may have bondo. Engine is all original - has the manifolds and exhaust on it, tranny is out disk/drum set up 8.75 but not certain what gear it has....
