[WANTED] 340 engine complete
looking for 340 engine complete or parts. That needs rebuilding.
If you receive a PM from me tomorrow I have given enough thought to selling one of mine (dismantled shortblock-steel crank.) But first and foremost I am 12 hours away from you and it will need to be picked up. If you are willing to make the drive great. If not, I understand....
JW
I have a 1970 340 block with a .040 bore that is fresh, new cam bearings installed, .040 speed pro forged pistons (used very little) new rings, rebushed rods with new ARP rod bolts, steel crank, rotating assembly balanced, #394 (69 340) oil pan, Mellings HV72 oil pump, Mopar purple shaft cam .294/.484 cam. $1000.00. PM me if interested
Got a '69 340 with #'s matching 4spd attached from a Swinger. Has shifter and linkages. No exhaust manifolds, air cleaner, fan. PM me with Q's
