[SOLD] 340 engine with J Heads
davescuda
Cheshire, CT
340 engine 1/21/71 casting date with a 2 vin on it, with intake and J Heads also with 340 engine mount brackets
1300.00
In Cheshire CT
I’d be curious as to the assembly date on that one Dave. Looks to be a 72 low compression build but an early 71 casting? 1.88/1.60 valves?
I will get to that date. Yes 72’s did not have the 10.5 to 1 compression, they were lower compression. Yes the casting date is 1/21/71. The 72 have the smaller valves but I will measure them again.
