[SOLD] 340 exhaust manifolds
hemisedan
Central Iowa
Believe to be 68-69 manifolds in excellent condition. Still has the original heat riser that is not stuck. Don’t know if it is operable but it is loose. Here are pictures of them. $525 plus ride.
#2863549 RH manifold 68-70 A and E Body
#2863553 LH manifold 68-71 A body and 70 E Body
Just to let you all know that these manifolds are still available. These are just about the best 68 Hi Performance 340 manifolds that I've ever come across. Are they perfect? Depends on what you consider perfect, but they are very nice. Look at the pictures, all they need to make the heat riser work, I believe, is the heat riser spring. I looked on a heat riser kit and it was over $300. It's getting harder and harder to find unmolested manifolds like these. These need a good home.
