Longgone
John/68 Barracuda & Dart
I`m trying to find out if anybody has a 68-71 340 (without air conditioning) that came with a fan clutch. I`d like to add one to my (non A/C) `68, 340 but if it`s not correct then I won`t.
I believe clutch fans for standard on all 340s. They used the same fans as Hemi's $$$$
I have a new clutch fan that comes with the mopar peeformance kit if your interested.
My 69 340 Swinger Non A/C car came with a fan clutch
I believe the early 340s had the fan clutch even if they didn't have AC. I run the Mopar Performance fan clutch on my engine. Fits great and to the average guy looks stock.
This is an original 69 340 fan/clutch from a non-AC Barracuda that I used to own.
Sorry, don't want to sell it. It's the one I run on my car...and as you've found, where would I find another?
hey longgone from what i can see the fan and thermal clutch drive pictured is almost correct for 68. the fan is correct for 68, but the clutch needs to be #2863231. that would be for a 68 340 with ac. i do not see a listing for the 68 340 non ac anywhere...that being said it looks like in 68 the 340's without ac didn't get a clutch fan. personally i would go with the clutch as unless you are going 100% concourse no one would fault you on it for haveing it. i guess that is why they went to the clutch setup in 69 as ma mopar felt it was needed. just my 2 cents
I`ve researched the part numbers too and have come up with the same numbers that you have. I think I might go for it and (unless I show the car at some major event) it should go over without much ado.
How much clearance is there between the fan and radiator? I could not get my fan clutched fan to fit on my 360 conversion so I am running a fixed steel slant six fan.
If anybody out there has a `68 340 fan clutch, part no. 2863231, could you please post a picture of it and a diameter measurement? I`ve found what I believe is the correct fan clutch but the numbers are no longer legible. Thanks
