340 heads alignment pins
72dustervs
Winchester, Kentucky
Putting a 340 together and looking to see if there are alignment pins to put heads on the block , I dont have them but thought that there should be some , correct ?
You are correct....did you have the block decked? Shop should have put them back in or at leased handed them to you. If you need some, LMK, I have some I will give you.
Yes the blocked had to be decked it was in bad shape , perhaps the shop misplaced them or there were issues , so if you have some yes I could use them
Some times they get mangled when you take them out and are not worth putting back in. Shop should have supplied new ones if that was the case.
JBurch, you are one classy gentleman. Members like you are what makes this site special. My hat's off to you, sir.
