35regal
- Joined
- May 18, 2008
- Messages
- 404
- Reaction score
- 2
right now i have the low profile 8 qt pan by milodon, it was fine untill i added the 1 3/4 hooker headers, the problem now is 2 tubes on each side are about 1/4 -1/2 inch away from the pan were it gets wide at the bottom. so im looking for a alternative , something that will hold 7-8 qt pan. i found a milodon 9 qt pan , but its massive , part#31390, the drag link goes thru the oil pan via -tunnel-channel.its 11 deep in the fron and 12 in deep in the rear , its a rear sump. I DONT LIKE HOW CLOSE THE HEADERS TUBES ARE TO THE PAN BECAUSE OF HEAT. IT IS A STREET CAR. THANKS FOR YOUR HELP. this is for my 67 notch.
