340 piston question
LImopar
Active Member
Ronkonkoma New York
Just picked up a 340 from the cousin of a friend. He did not know much about the motor as he received it in a trade. As far as I can decode it is as follows:
Block 2780930 date 6 30 70
Heads 3418915-G J heads
Intake 3512100 date 6 23 70
Pistons marked 030 and have 4 small half circle relief cuts in them
Here are my questions:
How can Identify the pistons in more detail (ie. comp ration/type)?
How can I tell if this is a forged or cast crank motor?
Did any of the J heads come with the bigger 2.02 valves?
The lower end looks real clean and looks like it was a recent rebuild before it was shelved. I would like to just freshen it up. Is the intake that I listed above worth using?. If not what type intake and what type and size carb should I run. I am looking for just a streetable motor to put into my 70 dart.
Are the J heads worth having cleaned up or should I look for something else.
Thanks for any help?
are there any #'s on the tops?
is there what I call a 'belly button' in the center of the piston?
how many eyebrow's/valve reliefs?
4 eyebrow's=9.1
2 eyebrow's=10.5
the 4 small half circle valve reliefs usually inticates a low compression piston,,,
the high compression 340 pistons only had 2 valve reliefs them..
there should be some numbers on top of the pistons..
the biggest intake valve from the factory is a 2.02 intake...
just measure how far they are down in the bore....
If it still has the '70 crank, it's forged.
Does the engine have the harmonic damper? The damper for the forged crank has no counterweights. The cast crank damper has a large counterweight on the front and is marked as for a cast crank only.
