340 rockers
Just going by the listing - they already don't know what they're talking about. If they indeed fit "All LA heads" then they should fit X and J.
However - if they are talking about heads using dual valve spring assemblies, they may need to be clearanced around the spring. That's fairly common. That being said, I don't think they are work spending the money on. Cheap rockers can lead to some expensive repairs fairly quickly if/when they fail.
Could the rockers in the pic be for a big block? Adjusters aren't centered on the roller tips!
I wouldn't trust off brands.
ok thanks guys, i'm trying to gather some parts for my 72 340, cam, lifters, springs, roller rockers
hey aaron68s i bought these same rockers/package from the same comp. they worked great for me,had to clearance them for big springs.i have made about 60 passes down the 1/8th 6200-6800rpms no problems.get the needle bearing ones
