340 spark plugs
I run NGK plugs (TR4 I think, need 2 check) in my 340 engines, always worked great!
i run auto lite 63 last time i bought them they were like 93 cents at walmart,
you may need to experiment with heat range,i have low compression because of the blower,,,,
The factory suggests a Champion plug , RN9Y. I`ve always had good service from Autolites though ,the AP65 would be correct for your application.
I also would start with a stock plug. I think you'll be just fine with that. Work a step cooler at a time to see if you can find an improvement at the track.
