Hi everyone, recently picked up a 70 Duster worth restoration.. Was told the engine was rebuilt shortly before it was abandoned due to owner passing away. It has not sat very long so I figured before I tear her down I would see if I can get her started.
All ready to fire her up and when I turn her over I get a nasty clicking sound and the engine turning over very slowly.. I figured possibly the starter sat to long maybe she is not kicking out like she should.. I picked up a new one and dropped her in.. First crank sounded fine, nice and smooth.. (would not fire because I had not put the coil wire back on....) anyhow coil wire now in place.. Upon starting I got that nasty clicking sound and it turning over very slowly.. Went over all my wiring, cleaned all grounds/+'s still clicking..
Pulled the starter, it appears I am catching a bit over half way tooth wise, ring gear looks excellent.. Put starter back in.. she turned over like a dream.. next attempted clicking back.. Loosened/tightened bolts on starter she will crank just fine (1) time.. then the slow crank click (loud click i should state) occur..
I have searched and read for last week and have yet to find the answer.. I would blame the starter if it was not happening with both.. the loose/tight then works fine once has me boggled.. Anyhow sorry for the novel, Thank you in advance.
Skez
Skez
