[FOR SALE] 340 stroker
pat d
Rating - 0%
0   0   0
340 stroker 416ci scatt forged crank rods and pistons (icons flat top) .30 over 340 block balanced rotating assembly then balanced again locally (Miami fl) not assembled yet speed master heads cnc ported 2.02. /1.60 valves assembled air gap style intake and 950 hp carb and a 528 purple cam $4500 for everything pm for any questions located in Miami fl
I have to look tomorrow only # I can see are 2780930-340-8 what else do I look for
Other side of the block has the date cast into it, and there should be a 3"x3/4" pad machined on the side of the block just above where the oil pan bolts too with the VIN number stamped on it.
Hey guys posted more pics think production date is 8-15-71 and # 28179588 but ck out pics I’m not sure on production date
