the t/a heads have special rocker setup needed because the pushrods are slighty moved on them i think, youd know if you had a set of t/a heads because of the special rocker setup
TA heads are based on the 360 J head....and have 360 casted on them...
My AARCuda has U on the heads..
the TA head share the same casting number as the 71 360 head...but they were listed as a different part number which is not on the head.....so some people see the casting number look in a book...and WOW i have TA heads...well..no you dont..
as said...the TA head take is own rocker arms....273 adjustable and 340 non adjustable rockers do not fit the TA head.
