[SOLD] 340 throttle and gas pedal assembly
cuda67man
upstate
Rating - 97.2%
35   1   0
this was taken off a 69 barracuda with 340 years ago. gas pedal with felt/cable/and linkage with bracket and slides. suppose this would fit alot of other setups as well 50 plus ship
well Jim it was on the 340 that was in the car. if it was changed at some point I don't know. I would assume if its on a 340 it will work on a 318/ 360/ 273 just the same or am I incorrect?
4bbl pics. Ur linkage may have worked, but not properly, but it isnt right by far. That is 2 bbl stuff from the mid to late 70s. Kim
well it was hooked up to the stock 4 barrel the car came with Kim and was working fine and everything lined up on it so it def wasn't hooked to a 2 barrel. I changed it out when I pulled the motor for something else and added a dual quad.
2 BBL vs 4BBL the left extends up and toward the carb correcting the geometry for the cable to connect to the carb.
Shoot I had to look twice to see the black bracket(2 bl) in behind. The OPs bracket looks same as your blue one? But his linkage(long slotted piece) looks similar to yours? That part is 2 bl I believe.
Could be, I was trying to show the difference in the bracket. My goof, good catch though.
I think I actually stole that picture from either here or fbay
