6 68fsh FABO Gold Member FABO Gold Member Joined Apr 10, 2009 Messages 503 Reaction score 34 Rating - 100% 10 0 0 May 2, 2019 #1 Contact seller Anyone has these 4 little bolts for a 340 windage tray or know where to get them?
65 Dartman 1 of None 65 Dart Sedan Delivery FABO Gold Member Joined Sep 24, 2006 Messages 13,687 Reaction score 4,534 Location Strasburg, VA Rating - 100% 174 0 0 May 2, 2019 #2 You should be able to find the right size at the Hardware store. Probably overkill but I’d use Grade 8
E engine man Member Joined Apr 12, 2016 Messages 19 Reaction score 5 Location pa Rating - 0% 0 0 0 May 2, 2019 #3 i believe they are 1/4-20 x 1/2 like 65 dartman said hardware store
6 68fsh FABO Gold Member FABO Gold Member Joined Apr 10, 2009 Messages 503 Reaction score 34 Rating - 100% 10 0 0 May 2, 2019 #4 Thanks guys, do you know if they have the one with that special washer attached to it, that doesn't come off?
halifaxhops It's going to get stupid around here! FABO Gold Member Joined Jan 20, 2014 Messages 86,957 Reaction score 67,219 Location Hoppyworld, PA Rating - 100% 215 0 0 May 2, 2019 #5 Grainger or Fastenal should be able to get them
6 68fsh FABO Gold Member FABO Gold Member Joined Apr 10, 2009 Messages 503 Reaction score 34 Rating - 100% 10 0 0 May 2, 2019 #6 ok thank you
72Dart6pack Harder Better Faster Stronger. Joined Feb 1, 2016 Messages 5,172 Reaction score 6,349 Location Michigan Rating - 96.2% 25 1 0 May 2, 2019 #7 Look for Sem bolts. Easy to Google and find them.
lemondana BlackDart Joined Dec 7, 2007 Messages 1,326 Reaction score 1,299 Location Southeast NE Rating - 100% 3 0 0 May 3, 2019 #8 AMK has the proper bolts.
Oldmanmopar Going left turning right FABO Gold Member Joined Jan 8, 2009 Messages 13,355 Reaction score 13,001 Location Danielsville Pa. 18038 Rating - 100% 43 0 0 May 3, 2019 #9 With no location under your avatar I don't know if shipping would be to high. I have several they have what is called a spin washer. $1.00 ea. plus ride. I also have the Main cap bolts and trays for 340's and one 360. yes they are different.
6 68fsh FABO Gold Member FABO Gold Member Joined Apr 10, 2009 Messages 503 Reaction score 34 Rating - 100% 10 0 0 May 3, 2019 #10 pm sent to Oldmanmopar
