May 2, 2019 #1 6 68fsh Well-Known Member Joined Apr 10, 2009 Messages 503 Reaction score 35 Rating - 100% 10 0 0 Contact seller Anyone has these 4 little bolts for a 340 windage tray or know where to get them?
May 2, 2019 #2 65 Dartman 1 of None 65 Dart Sedan Delivery FABO Gold Member Joined Sep 24, 2006 Messages 14,610 Reaction score 5,529 Location Strasburg, VA Rating - 100% 194 0 0 You should be able to find the right size at the Hardware store. Probably overkill but I’d use Grade 8
May 2, 2019 #3 E engine man Member Joined Apr 12, 2016 Messages 21 Reaction score 17 Location pa Rating - 0% 0 0 0 i believe they are 1/4-20 x 1/2 like 65 dartman said hardware store
May 2, 2019 #4 6 68fsh Well-Known Member Joined Apr 10, 2009 Messages 503 Reaction score 35 Rating - 100% 10 0 0 Thanks guys, do you know if they have the one with that special washer attached to it, that doesn't come off?
May 2, 2019 #5 halifaxhops It's going to get stupid around here! FABO Gold Member Joined Jan 20, 2014 Messages 96,638 Reaction score 83,396 Location Hoppyworld, PA Rating - 100% 274 0 0 Grainger or Fastenal should be able to get them
May 2, 2019 #6 6 68fsh Well-Known Member Joined Apr 10, 2009 Messages 503 Reaction score 35 Rating - 100% 10 0 0 ok thank you
May 2, 2019 #7 72Dart6pack Harder Better Faster Stronger. Joined Feb 1, 2016 Messages 5,196 Reaction score 6,407 Location Michigan Rating - 96.2% 25 1 0 Look for Sem bolts. Easy to Google and find them.
May 3, 2019 #8 lemondana BlackDart Joined Dec 7, 2007 Messages 1,783 Reaction score 1,976 Location Southeast NE Rating - 100% 3 0 0 AMK has the proper bolts.
May 3, 2019 #9 Oldmanmopar Going left turning right FABO Gold Member Joined Jan 8, 2009 Messages 15,690 Reaction score 17,777 Location Danielsville Pa. 18038 Rating - 100% 44 0 0 With no location under your avatar I don't know if shipping would be to high. I have several they have what is called a spin washer. $1.00 ea. plus ride. I also have the Main cap bolts and trays for 340's and one 360. yes they are different.
May 3, 2019 #10 6 68fsh Well-Known Member Joined Apr 10, 2009 Messages 503 Reaction score 35 Rating - 100% 10 0 0 pm sent to Oldmanmopar
