340 Windage Tray
gtxjeff
'65 Cuda 340
Portland OR
Hello All,
Currently building a 340 Stroker motor for my 65 Cuda drag car. My question is a simple one, does anyone know where I can obtain a windage tray the will work with a 372ci stroker crank.
Thanx Much
Hello All,
Thanx Much
Am I right in assuming your running a 360 stroke crank in a 340 block to get the 372 c.i.? If so the stock 340 tray will work
Thanks to Marcohotrod and 340doc for thier replies. In response to Doc340 I don't know if it is a 360 crank I'll have to check the specs. I purchased a complete rotating assembly from SCAT Cranks so I need it to arrive before I know what crank it is.
Thanx Much
GTXJeff
That stroker displacement is a .030 overbored 340 block and a 360 crank.
Old tyme stroker combo.
