Well, 1 and 7 are on the same side of the carb, and 3 and 5 are on the other side so something seems mismatched between the 2 sides. Nothing guarantees all cylinders will get the same on a given side so perhaps the side that feeds 1, 7, 4, and 6 is overall lean and 1 and 7 are getting less than 4 and 6. The other half of the carb feeds 3, 5, 2, and 8, and 3 and 5 are right under the carb and are getting more than 2 and 8, with that whole side a bit rich.
The reason to ask about what you are doing before taking the plug readings is that you will see the coloration on the plugs corresponding to what the engine/carb were last doing. So if you go WOT and then cruise back to the garage and read plugs, then you will see the mixture that the plugs saw for cruise and idle, not WOT. If you want WOT readings, go WOT a few times and quick succession, and then close the throttle and cut the ignition at the same time, drift to a stop, and pull plugs by the road for a true WOT readings.
Since we don't know how you are doing this plug procedure, it is hard to say what carb circuit the plug readings are reflecting. If a lot of idle just before plug readings, then it might be just the 2 sides' idle mixture screws being set a bit differently.
The carb may have something mismatched internally between sides.
BTW, is the engine getting fully hot? Not sure where 'K' is, but the Air Gap is going to be cold-natured and the temps are getting cooler these days. Perhaps the cool air on the non heated AirGap is causing idle and cruise mixture mismatches.
