[FOR SALE] 340
rrvolare
19Swinger69
Michigan
Rating - 66.7%
2   1   0
- .060 over .. 1 sleeve ( installed correctly ).
- forged steel crank
-milodon valves
- hardened seats installed ( 2.02 intake )
img_0345-jpg.1715007156
- 10.75-1
- rods polished , shot peened , sps rod bolts
- trw forged pistons
-HV pump
- moroso oil pan
- 273 new adj rockers
- banana cut rocker shafts
- victor junior intake
- holley carb
- GK cam
- balanced/blueprinted
- sold vehicle , kept engine
- been sitting , has no more than 20 cruises on engine .. recommend disassembly and checking prior to starting ..
- let me know if you have anymore questions .
2200 complete carb to pan ..
Been sitting ... i would ... what you do is entirely upto you... a GREAT price .... if it don't sell , i will put in the corner with the other 2 340's....people are asking STUPID money for a bare block anywhere between 500-1200????i spent alot of money on this motor.... around 400 hp
Understood. The one on the stand, correct?Tryin to decide if I'm goin 451 or smallblock. Will let you know. Any trouble with overheating at .060 when it was running?
on the stand .. no issues overheating .. just make sure you have a GOOD quality radiator and electric fan/shroud ... thanks
Solid ... 500 lift .. 300 duration ...From Holley DFDP Carburetor modified for this cam ...airhorn removed... primaries throttle plates we drilled a small hole so it could idle .. NO issues after that ... this motor pulled like a B*&^%.... I had it built when i lived in Canada .. by the person that owns LEITCH Performance now ..
