TomSchichtel
73 Duster
I have a 360/727 from a motor home (1972). There has always been an issue the the car will not coast fast at all. It will quickly slow down even while going downhill. If I put the trans in neutral then the car will coast and even gain speed downhill. I want it to do this while in gear and I figure it must be a somewhat idle stall torque converter that may have came with the motor home. (thats my theory) I seem to use just as much gas going uphills as I do going downhills (same throttle pressure). The trans shifts smooth and I have never had an issue with it. What can I do to solve this. Maybe its torque converter? If so what stall should I get? Thank You for your time!!
