1971dodgedart/6
would my machine shop be able to machine the crank for the pilot bearing? i was also told i would have to cut down my a833 input shaft to get it to fit, whats the real deal on getting these together? thank you
this is EXACTLY what i was looking for, thank you!The thing you need to do is mock it up and measure the depth of the pilot hole, it might be deep enough.
IF the hole is undersize, the easiest way around this is to NOT use the older bushing that goes in the original bore, but rather use the new one which fits in the large torque converter pilot. These come in either bushing or roller bearing
Found this on the www
http://m37.wawii.com/2005.5.html
(94 and newer, part number BCA #FC69907, or Mopar # 53009180AB) Pilot Bearing
magnified view:
http://m37.wawii.com/images/DSC04240_NewModernPilorBearing.JPG
