Charlesvolare
I'm going through and freshening up my 360 and checked bearing clearances this past weekend. Mains are on the looser end on 0.0015", rods are on the tighter end of 0.0015", using plastigauge. I knew they were gonna be tight, but I'd feel a lot better at 0.0020"-0.0030". My crank has been turned 0.010" under and I used a fresh set on 0.010" undersized bearings to check this. The only bearings I can find to help with this would be these 0.009" undersized bearings:
Clevite MAHLE MS1266HG9: Main Bearing Set Chrysler 1974-2003 V8 360 (5.9L) with -.009" Undersize | JEGS
Clevite MAHLE CB481HN9: Connecting Rod Bearing Chrysler 1956-2003 V8 273/301/318/340/345/360; V10 488 with -.009" Undersize | JEGS
Does anyone have any info on any other bearings? Or is it feasible to have the crank turned under that minuscule amount to use the regular 0.010 under bearings? Has anyone had any luck with polishing the crank that much and it still being true?
