moper
There are a few 750 Edelbrocks available. One sucks, the other two shouldn;t be too harrd to tune. On the street I'd take an Edelbrock on a milder engine like this over a Holley any day.
No offense to you, but there has been a thread for about every subject out there, so shall we quit with all new threads? Everyone just use the search tool? You saw the title of the thread said "carb", so don't click on it if it offends you. Now, to the question, I would say you at least want a 750for that motor....Use the search button. No offense but there has been too many carb and intake questions recently. If you can't find a good answer using the search tool then pull the carb off the shelf and see what it does. Doesn't take 15 minutes to swap carbs.
Its a matter of CFM....required for Maximum Air Consumption.
360 c i...... X MAX RPM........ / by 3456 = CFM
360 x 5000 / 3456 = 520.83 CFM
360 x 5500 / 3456 = 572.91 CFM
360 x 6000 / 3456 = 625.00 CFM
360 x 6500 / 3456 = 677.08 CFM
360 x 7000 / 3456 = 729.16 CFM
360 x 7500 / 3456 = 781.25 CFM
These numbers are pretty close to the Air a given Cubic Inch Displacement engine will move......
A 650 cfm carb would probably be best suited to your engine....because the smaller venturi's...the engines' Vacuum Signal to each cylinder would be improved.
I usually like to lean to the performance side and use a 750 on a 360 because it has larger venturi's and hence less air restriction......and a 650 or less on a 318.
