Future reference, drill the "heavy hole" crossways for Mallory metal. No welding needed and safer. ateam:cheers:From the looks of it, it may have been internally balanced. a hole is drilled into the counter weight & a section of Mallory metal is inserted. It is the welded in to secure. I can't say for sure about what you have. Since you heard it run, can the person you bought it from advise you on it?
