Cope
Fusing with fire
what is the purpose of the 360 degree bend in the brake line after the master? I installed my line lock and tried to double flare the old line going to the distribution block (front breaks) and it failed. my question is when I try an re make this line do I need that full circle loop in the line or can i just do with out? (pass tech inspection)
the line would be a little easier to make with out it but if it accualy dose something or is required then i will try and reproduce it.
Thanks for the time and advice.
