[SOLD] 360 Engine blocks - Early 1970's - Standard bore
Rocket
CT
For sale are 2 1972 360 ci small block engine blocks. The casting number on both blocks is 3418496. Both are standard bore. This casting is the first production 360 block casting (1971-1974) and is rumored to have thicker cylinder walls than later castings. These blocks are a great choice to build a performance stroker small block.
The first block comes with stock main caps. Price $150. Prefer local pickup.
The second block comes with stock or aftermarket 4 bolt main caps for mains 2, 3 and 4 and the stock caps on the 1st and last main. The 3 center 4 bolt caps will require installation. Price $250 with 4 bolt caps or $150 with stock caps.
The 4 bolt caps can be purchased separately for $100.
Local pickup preferred on he blocks.
The good deals are too far AWAY
