Xe268hWhat cam is the red lines?
Plus 1.6 rockersThank you
maybe not turn in your man card, but somebody should definitely take away your tools at that point.If you can't get a 9.5 360 with a xe268H to run on pump gas, you need to turn in man card. FFS
360 heads are open chambers. You cannot get any Squish/Quench out of that combination
Ok, cool. Thank you sir! My knowledge starts thinnin out the later model the engine is.....but then, my knowledge is pretty thin to start with. lol1989 was the first year for roller cam 360 block. Just picked up a 91 360 with 110,000 miles the other day. Haven't pulled it apart yet.
Milling of the heads will take care of that.If you can't get a 9.5 360 with a xe268H to run on pump gas, you need to turn in your man card. FFS
To the both of your replies…maybe not turn in your man card, but somebody should definitely take away your tools at that point.
Your correct. My understanding is that the crate engines were .020 over for this reason. And Mother Mopar added cooling ports along both sides of the upper center head bolt boss...Mag'n the block is mandatory.Ok, cool. Thank you sir! My knowledge starts thinnin out the later model the engine is.....but then, my knowledge is pretty thin to start with. lol
I have some H405p ? .040” pistons I would sell to you for $160 plus shipping.I have a stock 73 Dart 318 automatic that I would like to get a little more out of it. I am not interested in fixing up the 318 at this time. I have gathered the following parts, an 86 360 that needs to be bored 40 over. 360 heads with 202 valves, Edelbrock dual plane intake, Edelbrock 600 carb, Roller Rockers 1.5, MSD Distributor & MSD 6AL2 box and coil, Headers & 8 3/4 Suregrip 3:55 gears. I am looking for a mild build. I am looking for recommendations for pistons and cam.
I believe 1986 is the beginning of roller engines for 318’s and 1988 is the beginning of roller engines for 360’s.Is the 86 engine a flat tappet or roller LA? If roller, that's a lot of territory already covered.
Is that a roller block, and do you have the roller lifters, dog bones, and spider to reuse?
What heads # do you have.
You can't go wrong with the aforementioned kb107 pistons for price, but even though not a big horsepower loss, I still personally avoid 5/64 ring packs anymore
