Xe268hWhat cam is the red lines?
Plus 1.6 rockersThank you
maybe not turn in your man card, but somebody should definitely take away your tools at that point.If you can't get a 9.5 360 with a xe268H to run on pump gas, you need to turn in man card. FFS
360 heads are open chambers. You cannot get any Squish/Quench out of that combination
Ok, cool. Thank you sir! My knowledge starts thinnin out the later model the engine is.....but then, my knowledge is pretty thin to start with. lol1989 was the first year for roller cam 360 block. Just picked up a 91 360 with 110,000 miles the other day. Haven't pulled it apart yet.
Milling of the heads will take care of that.If you can't get a 9.5 360 with a xe268H to run on pump gas, you need to turn in your man card. FFS
To the both of your replies…maybe not turn in your man card, but somebody should definitely take away your tools at that point.
Your correct. My understanding is that the crate engines were .020 over for this reason. And Mother Mopar added cooling ports along both sides of the upper center head bolt boss...Mag'n the block is mandatory.Ok, cool. Thank you sir! My knowledge starts thinnin out the later model the engine is.....but then, my knowledge is pretty thin to start with. lol
