Yep, 90 roller motor with new magnum heads and a Bullet racing cams roller cam. Some work done on the heads, nothing over the top. I torqued the heads to 60lbs today and will torque them later on in the week. I'm using a Mopar M1 dual plane manifold. Here's a few more pics with some pieces on, it's finally coming together.
I prelubed it yesterday, forgot to put the oil pressure sender in. It does have oil pressure! I'm waiting for a new water pump and fuel line. The rockers are rough adjusted and I used a new mini starter.
