65mopar273
Member
- Joined
- Jan 22, 2010
- Messages
- 15
- Reaction score
- 0
I have a 99-5.9 magnum that i want to put in my 65 valiant , a friend gave me a aluminum intake Edelbrock #2835139 LD4B this intake wont bolt up to my heads because the magnum heads have a straight down bolt hole an the intake holes are at an angle, now would heads from a 77 jeep with a 360 work on this magnum ? the jeep has shsft mount rockers ant the magnum has pedisal mount rackers which push rods would i have to use, also the magnum heads have 4.6 in white # from the factory what does this mean? i am going to have the engine re built so changeing the heads is ok if i can find the right ones .8)
