eccentricMagpies
I'm assuming i need to run the heater hose to the circled plug but figured I had better confirm too.
thanks,
thanks,
I'm assuming i need to run the heater hose to the circled plug but figured I had better confirm too.thanks,
yeah... seems i had better check the NPT first as you mentioned, according to this note:
"...The 5/8" hose fitting screws into the intake manifold and water pump on 1965-69 models, and the water pump only on 1970-1974 models. "might be this guy: 1966-74 A B E-Body Heater Hose Fitting
