tjgp360
Active Member
the engine was just "rebuilt" less than 2 years ago by some screw ball mechanic,.....thats another story
after this "rebuild" i noticed the car often stalled whenever i used the brake, i blamed the leaky brake booster, so in the meantime i just up the idle a tad to to keep me going
a couple , months after i remove the lean burn and install a jegs ignition kit
soon after engine started to make a ticking/tapping sound (like a bad lifter)
a few months later the timing cover gasket blew causing coolant to spew everywhere so i park the car for a week while i get ready for my own rebuild
I bought:
summit cam -6901 with lifters
camshaft gasket change kit
edelbrock 1406 carb
thermoquad carb (rebuilt it my self)
stock cast iron 4bbl intake
edelbrock performer intake
Power brake booster
Master cylinder
DURING THE RE-REBUILD
the rebuild went smooth, but during the tear down i noticed that a rod broke through a rocker arm, so i hit the junkyard for a replacement and i also noticed that 2 lifter were worn to hell 1 actually had a small pin sized hole in it, needless to say the camshaft lobes they rode on were practically gone.
I installed the edelbrock carb simply because :
1. im not sure if i totally trusted my rebuild skills
2. the new intake gasket had the heat crossover blocked and well...the edelbrock has an electric choke
3. the carb gasket that i bought fit the edelbrock but was too small for the manly secondaries of the thermoquad:burnout:
AFTER RE-REBUILD
after everything was assembled i took some time to tinker with the distributor and it started right uprayer: but i got too happy too fast:banghead:
KNOWN PROBLEMS
i got it to idle okay but now when you drop it into gear it likes to drop from 580 to 640 rpm down to 430 450 rpm then stalls!!!!
im not sure how to tune this damned carb, all i did was unscrew the 2 screws 2 1/2 turns.
Sometimes i can hear a hard ping other times i don't
the carburator spits or back fires sometimes when i snap the throttle wide open then stalls out....
i cant even drive down the street and turn around with out it stalling 8 times!!:mumum:
ON TOP OF THE THE BELT MAKES A DAMN NOISE NOW WHEN I TURN THE WHEEL HARD!!!!:angryfir:
i need some help or advice or something because even though my car isn't the prettiest i still love the damn thing to death and im just HOPING i can make the Woodward Dreamcruise
I bought:
edelbrock 1406 carb
Power brake booster
Master cylinder
AFTER RE-REBUILD
KNOWN PROBLEMS
