[SOLD] 360 Magnum out of 2000 Ram
72DMag
Pittsburgh
Located in the Pittsburgh pa area. Shipping available!!
I have for sale a 360 magnum that came out of a 2000 dodge ram. The block and engine was in running shape. I took it apart and was going to rebuild and install in my duster but went with a big block instead. The motor and crank are in excellent shape and a rebuild can be done at home with no machine shop work necessary. You can still easily see the cross sectional cuts on the cylinder walls. Asking $360 plus shipping obo for everything (Complete engine which is heads, intake, exhaust manifolds, intake manifold, throttle body, all the bolts, etc...)
Will also trade for a 950 cfm holley/demon carb really need one for a build!! Or 72 duster parts, big block parts. Or 90s 4x4 suzuki quadrunner. Or chrysler 400 block/motor Thanks!!
I have a 5.9/360 crate motor. I am interested in the complete serp belt brackets,bolts assembly. Price and shipping to 92555 So Cal.
Thanks
@408 swinger The 75 and earlier blocks are a little bit more desirable due to their slightly thicker mains. But a 76-78 block will work just fine for me!! Thanks!
im above you in western ny.
if you feel like making a drive,i have several 400-s,that are together and ran when pulled.
springwater 14560
