360 motor build
marcus
Active Member
Puyallup, WA.
I am new to the classic car scene. I have a '70 Dart that I am currently playing with. It has a 360 in it that runs well... I have the chance to buy a 360 for a fair price, I am wondering what components I should use in the motor to get it to around 400hp. I don't have tons of money, and I know I may have to bore it over which is fine... Any help on this would be awesome!! thanks.
use stock crank and resize rods...get KB 107 pistons...
have block squared and deck to zero deck height with those pistons...
cylinder heads are going to make it or break it..
if you can afford it...buy a set of RHS/Indy heads done and ready to go...
edelbrock air gap would be the choice of intake unless you have something else already
And if you cant afford the Air gap I have a cross wind which is port matched and is a comparable substitute to the Air gap until you get the cash for the eddy.
