cuda27365
cuda27365
I have a 1967 barracuda and pulling out a 318 to put in a 360 what flex plate do I need
yup...the earlier engines have a 4th bolt that has a hole through the middle for the chain oiling.It is for directing oil onto the timing chain.
Chuck
You can bolt in the 360 with the following notes.....You'll need a bushing for the end of the crank for the small button converter (I think Mancini has them); A custom 360 converter for your trans or the B&M flex plate for your existing converter; motor mount brackets that will fit the 360 block and your K-member (Schumacher or modify your 273 ones); a 360 car oil pan, and a custom exhaust system. Most everything else should transfer over from your 273. If it's a true '65 model, it would not have a push button transmission. '65's were still cable shift but either on the column or the floor.i want to put a 360 in a 65 barracuda in front of a 904 push button that i believe is the original. i believe i have a flex plate from years back that i had connecting a 360 to a 727 from a 64 A100 van. how do i check the tranny and motor to determine what will work?
thanks
A 318 pan won't fit on a 360 and there are no stock exhaust manifolds that fit both the car and the 360 heads without modifying something. Semi fender well headers? So you only have to cut a hole for one or two pipes instead of four? You still have to cut a hole..... does it really matter how big?thanks for the info, typo i have a 64...i know there is an oil pan problem, any idea if my 318 oil pan will bolt up fine to the 360? hoping to find some of the 360 motor mounts at our big mopar swap meet up north in a few weeks. my dad has a set of semi fender well hooker headers for the car but i hate cramming in headers where they just dont fit so i might be putting the stock manifolds on......but not sure on that yet. we will see how motivated i am to customize when it comes down to the swap. i also want to see someone that has the fender well headers installed to see all that needs to be done instead of a weekend of trial and error and scratching paint.
Yes, the four threaded main cap bolts are for a windage tray. As far as need, you'll have to decide that depending on what kind of RPM's you'll be turning. Oh, and a 273/318/340 windage tray won't fit a 360 either.On my 360 before I put my oil pan on there are four maincap bolts that have threaded holes in the end of them,is it for a tray and do I need it?
The 273 manifolds will bolt on but they won't flow good and usually won't keep a gasket as the port sizes are a lot bigger on the 340/360 heads. As for fender well headers, I just don't like them for the street. I don't like to cut up the car to begin with but unless you're going to run "pizza cutters" on the front, they're pretty hard on tires. That extra heat can scorch them good.you mentioned that early a body manifolds wont bolt up to the 360 heads? i thought all the small block heads were interchangeable? and the fenderwell headers look like two of the tubes exit the inner fender but the they all collect down next to the tranny like most headers, not in the fender well. any experience with those type of headers?
