dartslantsix
I searched and could not find an answer. The rear main cap gasket on the oil pan is my problem. The ends of it stick up above the rails of the pan and I'm not sure it will stay in place as I'm trying to install. (engine is still in car) It looks like it might be better to install it on the main cap first as opposed to the pan. The other three pieces of the gasket will install to the pan just fine.
Is this the best way to approach it? Is there any trimming to the cork that needs to happen?
