bricud
Cuda's Cuda
I pulled out the factory 318 out of my barracuda and am building a 408 stroker for it. The block is a 1973 LA 360 with a Molner rotating assy for 408 ci and wondering what is recommended for an oil pan and oil pump pick up for it. I want plenty of clearance and wanted recommendations on the pan and oil pump pickup type to match. I have a high volume oil pump but don't have the pick up tube yet. This will be a 525 hp/540 ft lb engine. Thanks,
Brian
Brian
