I have a 1969 Dart with a new tubular K member suspension. I bought a 360 dodge engine with a 1988 block. The oil pan on it is a rear sump( of course) which will not fit into the Dart . Can I just switch oil pans with a stock auto pan and get a sump change or am I in a pickle?
Welcome to the forum. 360 car pans are fairly plentiful. Remember they are different from the 318-340 pans.
If you have the clearance use a Dakota V8 pan. With the tubular k frame is the steering linkage moved from the stock spot?
Thanks for the replies, very helpful. This is a mild motor so no need for an extra deep pan. Everything on the tubular part remains in the same place but there is a bit more room in the center . The truck pan hits the center link though.
