Can fabricate steel "L" bracket off the driver's side front upper head 3/8" threaded boss if you don't want to risk the water jacket and aluminum manifold also.
TRWracing, is the question: If you take two bolts (disturbing a sealed gasket in the process)out of your intake to install a bracket will you cause a leak after reinstalling the bolts?
