360 replace throttle return spring bracket
TRWRacing
Chicago
Hoping to install a stock style bracket on the front 2 intake bolts on a Air-gap style intake. Am I risking an intake leak by doing this?
Can fabricate steel "L" bracket off the driver's side front upper head 3/8" threaded boss if you don't want to risk the water jacket and aluminum manifold also.
TRWracing, is the question: If you take two bolts (disturbing a sealed gasket in the process)out of your intake to install a bracket will you cause a leak after reinstalling the bolts?
It’s a 50/50 chance either way. Drain the rad so no coolant can seep in between the gasket. I have done it a few times with no problems. Kim
