dpmalibu
I had these listed before but decided to relist with lower prices (there are pics in the older thread):
1) 1979 360 Shortblock w/ low miles approx. 40,000. Stock bottom end/ dish pistons. has brand new Mopar Performance Purple stick Hyd. flat tappet cam. .478 lift 238 dur @ .050. 110 lobe separation. The cam is broken in and just has run time no miles on it. It also comes with the oil pan, new timng chain, chrome timing chain cover and new water pump. Asking $475
I have a video of the car running before i pulled it (I can email it to you) . It did not smoke or burn oil.
2) I have a stock rebuilt 904 trans and 11" TCI Breakaway torque converter (2400-2600 stall). Both came out of a 1973 Plymouth Duster That I just parted out. Both have less than 50 miles on them.
Prices are the following
Trans $450
Torque converter $225
3) X heads : Completely rebuilt and ported also. Comes with stock rocker arms. Heads only have some run time no miles. have receipts/ flow sheet. $1350 Heads are good up to .540" lift
Copies of paperwork for heads are posted in older thread.
Located in Hatboro,Pa
Trans $450
