Just joking around with you.
No, I saying you might be able to sleeve it.
It isn’t really cost effective.
Early stock heads like a X or J head or older W2’s.So...open chamber heads. What are the options?
For power, if you have the coin, go W2.
The stock heads, as cast, do not support much power even on stock displacements. Porting a stock head quickly escalates in money to aluminum head money.
You could still do very well with a stock head. Though it’s choking the engine @ 400+ cubes.
Reading, “a street engine that never see’s the high side of 5500”, a lot of power can still be made down low.
I thought is was less. .018? IDK, it’s crazy early for me right now.I don’t think it’s considered open chamber but the 65cc version of the small block head has room in the chamber to clear stock high compression 340 pistons which are .025”-.030” above the deck. I think they are PN 60175.
