67_Slimer
Real Hot Rods don't shift themselves.
So I finally found a 360 to begin my build with. It's a standard bore 1975 motor. It's going in a 67 dart with a 4 speed and Dana with 4.56s. I currently have a mild built 340 with edelbrock aluminum heads , Victor intake and a 750 race brawler carb. I'm definitely building a stroker from the 360 , just not too familiar with anything other than the 408. I'd like at least 500hp and a low - mid 11 second street car. What are some other stroker options? do some rev higher than others? I'd like to use my current top end on this stroker , would that work? I'm not afraid of compression or a big cam. Whatever works. I just don't want to build a stroker , only to put it in and have it be pretty much the same power as my 340. Thanks for any input.
